Red-KAT wrote:Mine stalls and I have no bov... So mine is not that... Also mine never did this befor turbo so its not my idle...
I think the MAF being to close could be the issue... Now I want to move mine out farther to see if that works...
daniel240 wrote:i have not tried that yet. i still want to fix it the right way though.
Kool240 wrote:Hey dudes I know why your cars are dying under normal idle if you go to the trottle body of you car there is a small hose that comes off the bottom. it normally is connected to your in take. This has a small bb inside of it and is a negative pressure line when your throttle body is closed a vacumm is put on this line to let a small amount of air into the intake so the car does not choke out. Thats why some of you guys are half *** correcting it by raising the idel on the throttle body make sure that tha tubing is in the intake perferably before boost if possable. so it get the right amount of negative pressure at idle................. Then take it for a run and it should correct its self.......... Good luck.......![]()
nismo1003 wrote:I plug that to the charged pipe, if u unplug it , your car shoudl be fine in idle, and it does vaccum when it is under idle.
daniel240 wrote:well i tried it today and it didnt fix the problem. i think it may have helped it though. i took it up to about 3k and shifted to N and it didnt stall or drop below normal idle. but i took it up to 4 or 5k in 2nd and 3rd gear and shifted to N and the rpm's droped below 500 and i quickly gave it some gas. i dont know if it helped or not because i havent driven it much but i think it did. but it did not fix the problem completely. i connected the small hose into the larger crankcase breather hose right before the intake with a connector. this was easier than drilling a hole in my intake. this would be the same as having it into the intake wouldnt it?
