Try cleaning it first following these instructions from Q45.org.:
http://www.q45.org/maf.html
At the same time clean the connector. If it shows any corrosion then all the rest of your electrical connections are also suspect and should be inspected and cleaned as needed.
If the MAF cleaning doesn't work then you have options:* Swap in a known good MAF from another Q (easiest option)* Electrically troubleshoot following the FSM and NICO posts (PITA)* Buy a used MAF (Risky and cheap)* Buy a new MAF (expensive, $300+)
Now that you've read the codes and left it laying on the floormat, reset it and drive around for a while to verify that is the only code coming up. Good luck.
