Stalling Problems on Titans
bvalleri
Car: 2005 Nissan Titan
Truck runs for long periods of time at a stand still, but while driving it will stall out. Sometimes it will stall out at a redlight.There are no warning lights on.What could be causing this??
jwerty1
Car: 08 versa sl cvt blue, 08 frontier se 4x4 kingcab 6sp storm gray
take your mass airflow sensor out of your intakeit's right behind the airbox towards the engine and is held in by 2 phillips screwscheck the inside of it for debris, blow it out with compressed air, or if you can just by blowing into it, i've seen a some of these that get a leaf stuck in them or some kind of debris that causes the engine to get bad maf sensor readings and stall out, if this does not work you can swap out the maf sensor with another, most newer 03/04+ have the same maf sensor so if you have anyone you know with one it would be an easy swap and will give you a fool proof answer
this is the only thing i've seen with titans stalling, it could be something else, but i know i've run into it a few times, it's never thrown a code for me either, the first time i ran into it i spent several hours tracking down other stuff, but i would check the maf sensor first as this fits your description to a T
CPS
We have seen this issue a couple of times at our dealership and it was the IPDM-ER, which is the Intelligent Power Distribution Module - Engine Room. That could be the source of your problem.
pm_page6776
Car: 2009 A/C 2.5S
Good call on the IPDM. I agree
carmo
Car: 92 Accord, 90 Civic, 89 240sx
CPS wrote:We have seen this issue a couple of times at our dealership and it was the IPDM-ER, which is the Intelligent Power Distribution Module - Engine Room. That could be the source of your problem.
+1 for IPDM-ER
