stalling problem
bmoreadi
Car: 93 240 HB
ok so i finally got my s13 on the road today after 7 long months of hell on earth. red top, greddy M fmic, greddy bov open, koyo rad everything else is pretty much stock. she idles perfect. heres the problem... as soon as she sees boost and i go neutral, rpm drops and stalls, she stalls almost every time. is this due to open bov??? boost leak?? tommorrow i will check for leaks, and try to figure this thing out.. any ideas???
SpeedRacer1
Car: 1990 240SX, G35
Thats the atmospheric BOV venting.
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
Depending on the BOV you can adjust the bolt in for a harder setting on the bov this will usually solve the problem. If it is a GReddy it is fairly common to have to adjust it in. HKS SSQV seems to be better about this and not need as much adjustment. Phase2motortrend has an adapter if you want to recirculate or you can call them and get an anti-stall mod for the GReddy BOV. It isn't listed on the site i dont believe but if you call they have them in stock for about $30. In the future upgrade to a D-Jetro fuel system and you can atm vent the bov without any problems, ever. I recomend going the GReddy route but others like the APEXi route.
nwmrkt
Car: S13
you can tune it with a safc and that will solve the problem as well as make your car run better.
