NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Wed Aug 10, 2005 6:25 pm
where the harness is strapped to the intake tube wiggle it there. If you have cold air intake and have removed the rubber boot then locate the white stripe on the harness going to the maf. There is a common problem where it was tie wrapped to the boot and was pulling back on the air flow connector causing it to break contact from the air flow meter terminals. With the car idleing kinda wiggle the wire and gently pull it so it goes taut between your grip and the meter.If it dies you found the problem. just push it so there is excess on the maf side and tie it back down.
