Stalling out, but only some times
Zydeco
Car: The poster formerly know as -]sTm[-HeavyHips
Ok. This only happens sometime but its getting rather bother some to me. When Im driveing and i push in the clutch and the rpm drop to 0 and it stalls out. This only time this realy happens is when the car is all warmed up. I can avoid it stalling out by down shifting and keeping the rpms up. The check engin light only comes on when it has stalled out and goes off then i start it back up.
1992 240sx coupe, 5 speed w/135,xxx miles.
Thanx in adavance Dustin.
Sorry if your reading this twice. I posted it in the wrong fourm.
drjohn
Check for vac. leaks and possible coolant temp sensor connection. If you have a exhaust leak before the frt. O2 sensor this will through the O2 sensor out of calibration when driving and cause it to stall when you get to idle. Check for leaks in intake between airflow meter and throttle chamber.
Zydeco
thanx.
nismostreetracer
Car: Cars, Sports (Go Bucs!!!)
Check your vacuum hoses. If you hear hissing when car is idling that's your problem.
Zydeco
If it is a vacuum leak wouldn't it happen all the time?
iliketocrash
Any update on the situation? Did you ever find out what the problem was? My car does the EXACT same thing. Its getting really annoying.
