stalling not starting
dane68
Car: 1995 Q45
I have a 1995 q45 that has stalling problems. It used to start back up after about 20 minutes, but now is dead. I've put in a new fuel pump and module(used).The old module a pin burned out. But it still will not start. The MAF looks good,I don't know what to do next. Will appreciate any ideas.
black g50
Car: 1994 Q45 Black/Black--235/40/18's avh3100 xplode 12" and amp 160000miles.2001 rodeo 190000miles
Mine did that out front of Walmart fully loaded with frozen foods.After trying to let her start on her own I just gave it gas to about 2000rpm for 2min.Hasn't happened since....Oh one more thing,when I was trying to let her start on her own.with the headlights on,she wouldn't die down as fast as with em off. Electrical????
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
dane68 wrote: I've put in a new fuel pump and module(used).
did you inspect the used FPCU?
dane68
Car: 1995 Q45
The used FPCU looks fine, no burnt pins. I don't know how to test it or what to test it with.
Romeo5k
Car: 1995 Infiniti Q45~296k miles -- DEAD
2012 Nissan Altima 2.5 == 100,305 miles
Is the fuel pump coming on when u turn the key to on.. If not, something is wrong somewhere.. U should hear it running with the key in the on position. If you hear it,, time to move to something else.. If you dont.. Then we need to possibly ground the FPCU to see if it will run wide open.
1. Do you hear fuel pump turn on with the key in the on position.. You may only hear it for the first 5 secs, so play close attn.
2. If its on.. lets us know.. if not... let us know.!! (turn the radio off.. so u dont confuse antenna noise with fuel pump noise.)
dane68
Car: 1995 Q45
It doesn't sound like itis coming on. Do I need to get a ciruit tester and check the circuits or what ?
black g50
What about the relay in the trunk?Does it click?
dane68
Car: 1995 Q45
nothing, no noise at all
black g50
You have to pull the trunk trim near the antenna there you will see the relay,have someone turn key while you feel and listen for click from relay.
black g50
Forgot,make sure you didn't pull the ground wire loose from the top of the fuel pump holder thing,the weld is kinda weak(dont ask).Check fuse also.
dane68
Car: 1995 Q45
ground wire is secure, relay does nothing and the fuse is good
black g50
Switch out relay in trunk,it's supposed to click.Have you tried the method to take out the fpcu and run pump on high speed?
black g50
Spray MAF with electrical cleaner till bottle empty.
dane68
Car: 1995 Q45
haven't changed the relay yet, can't get one until tomorrow, did try the by-pass and got nothing. I had trouble getting the connector off of the MAF, I was going to spray it but I couldn't get it off, didn't want to break it
Romeo5k
hold on... You tried jumping the white wire?? As in splicing the white wire.. and tapping another wire into it and then grounding the other end to the body of car? Or you did something else. If you havent tried that.. i say give it a try.. Takes about 5 mins. Splice the white wire going to the FPCU (NOT CUT.. SPLICE!!) and connnect like a speaker wire to it... Then take the other end.. and ground it to one of the screws in the trunk. See if that works.. If it does... Let us know.. If it doesnt.. Still let us know.. But go to junk yard and buy another fpcu <-- (THATS MY OPINION) Not unless u know someone with the same kinda car and u can plug it into theirs and see if it works.
******* Just thought of something..:
On your old module, which pin burnt out??? Or which color wire connected to it if u dont mind me asking ...
The new fuel pump... New as in NEW TO YOU??? or new as in bought from autozone, oreilly.. etc??
htbyrico
Car: 1996 Inifiniti Q45/ Nissan President
heres some wiring diagram.. check for power with test light on all the yellow highlighted wires if all fail to work.. please make sure you click on the pick to zoom in and then press the + sing upper left corner to zoom in some more..
dane68
Car: 1995 Q45
On my old module, facing it, it was the top left pin that was burned. The method I tried to jump with was an alligator clip onthe lower left pin hole of the connector to an unpainted ground.
goody90q45
Car: 1992 Infiniti Q45 (sold)
dane68 wrote:haven't changed the relay yet, can't get one until tomorrow, did try the by-pass and got nothing.....
If you're bypassing the FPCU it takes the relay out of the circuit...the fuel pump runs on high speed only when the engine is started. Make sure you're jumpering from the correct pin on the FPCU connector as shown in the pic.
Have you looked at the fuse with a magnifying glass, or tested for continuity with a volt meter? Don't rely on a quick look as the break in the fuse can be so small you'll never see it with the naked eye.
black g50
Maf connector comes off after removing thin metal clip.Needle nose pliers or something similar.Googled your problem alot of answers pertain to the C.A.S...or I.A.V.
dane68
Car: 1995 Q45
That is the pin I was trying to jump from. I don't know and cannot find a diagramto show me exactlywhich fuse it is, soI checked them all,the ones under the hood. Are there more?
goody90q45
The fuel pump fuse in in the fuse box under and to the left of the steering wheel.
htbyrico
im guessing the cars fixed??
