Turbo_gotti »
https://forums.nicoclub.com/turbo-gotti-u165424.html
Sun Aug 01, 2010 6:12 pm
'89 240sx with S13 black top with E5 ecu.
had the car since '06, did everything myself the same year. probably put 100k since the swap.
the problem I'm having is at first i had an extended crank, but car ran fine. no issue with starting or driving the whole day. the next day is was it was driving fine then it started stalling out when i slow down every time, but its fine at WOT or accelerating. now the next day car wont idle at all, extended crank when only throttle is open. runs fine for 5 sec at first start then it starts misfiring then shut off. i can keep it running if i feather the throttle pedal at idle. wideband reads 16.0 afr all the time and once i let go the engine starts to studder and shuts off. fuel pumps have 12volts going to it while priming and when i can get it running. fuel pressure is good at 36 psi when it primes and when it does runs. when i disconnect the maf sensor, i feather the throttle to keep it running, then after 10 secs it would idle fine but afr flatcuate from 10.0-16.0. i replace the maf with another working s13 sr maf and redo the whole wire harness to clean it up. still the same issue. ground is good, has 12 volt in power wire and the signal wire have 0.5 volt when connector is plug in when key on engine off and 12 volt when its disconnected. tps tested good, all injectors are working with a noid tester, replace spark plugs. im thinking the ecu is bad. what do you guys think?
history
2006
aug- swap done
oct.-safc install. 13.7 at 104 t25 at 7psi. stripped interior
2007.
jan.- z32 maf, retune
feb.- meth injection, retune
aug.- replace fuel pump (no start issue)
2008.
mar.- remove meth (pump fail) retune
jun- replace fuel pump (stalling issue when electric fans kick on)
july 13.2 t25 at 15psi stripped interior
2009.
mar- s14 t28 install retune at 15psi, elbow upgrade replace fuel filter, heat7 plug
jun-12.9 at 111mph full interior
jul- replace all couplers and vacuum hose
dec. reseal front cover replace front crank seal. reset ignition timing.
2010.
jan. safc removed burnt screen but still holds tune. sohc maf. 7psi
stock cat back. too many exhaust tickets in one month.
apr. had contaminated fuel. clean tank. replace pump and filter. perform injectors service.
may- s14 turbo blown upgrade to s15 with screamer elbow. 7psi. drive like an old lady since upgrade.
july. now this issue.
