The problem is not constant, it comes and goes. When it comes it's harsh. I cleaned the MAF sensor tonight, so I will see if the problem returns. If it does I will unplug the sensor, thank you.Ramius83 wrote:This problem sounds MAF sensor related. Unplug the harness going into your MAF sensor, which is the sensor located directly left of the air intake box lid. If you unplug it and the problem changes, then it is your culprit.
magic_max wrote:Did you fix your problem? Where did you get your MAF?
I had stalling problems myself which turned out to be the MAF. I posted about this. I went the long route in troubleshooting my problem. Cleaned IACV, EGR tube.
