i turboed my 1993 3 years ago,i did ever thing to eleminates this problem, by use 3 different BOV ,reciculates ,atmosphere.every thing u name it.post my problem on this forum,and other 240sx forums.i have been working with nissan for 20 years and nissan master mechanic.listen what i am going to say after i asked every body..no answer ,i am going to tell u what u need to do.if u want to contact me that's okmy email :
[email protected] make sure there is no vacum leaks. timing and idle set right.sounds a lot of work but results is real..move the AFM and install it before trottle body,u can add coulpe feet of the afm harness u should be oki did that my problem solved after long time of agrivation. i have the oem AFM, then i replace it with q45 and 370 cc injector and no s-afc or any fuel manegement..runs great 250horses/with8 pSI, i stretchet some time to 12 pSI sturve at top end..i am happy...mail me if u have question..good lucki hope that i helped some body that stuggling to find the solution for this problem...
