fbh11201 »
https://forums.nicoclub.com/fbh11201-u57976.html
Sat Feb 24, 2007 1:34 pm
I had the same problem also, but it was my o2 sensors (oxygen sensors). There a pain to replace due to there location, but definitely a diy. The are 2 of them, 1 on each side of the vehcile. The one on the passenger side, you will need to remove the battery to get to it. The one on the driverside is under the master cylinder. The driverside will be a little challenging (because of the obstacles), but it took me a total of 2 hours from start to finish for both sides.
