Stalling but only some times.
Zydeco
Car: The poster formerly know as -]sTm[-HeavyHips
Ok. This only happens sometime but its getting rather bother some to me. When Im driveing and i push in the clutch and the rpm drop to 0 and it stalls out. This only time this realy happens is when the car is all warmed up. I can avoid it stalling out by down shifting and keeping the rpms up. The check engin light only comes on when it has stalled out and goes off then i start it back up.
1992 240sx coupe, 5 speed w/135,xxx miles.
Thanx in adavance Dustin.
Cloudedone
Car: Cars, Drifting, Auto Mechanics, Army, Chicks
Sounds like a posible vacume leak to me, posibly on the intake manifold side... sure you got your AEM Installed correctly?
Zydeco
Well I have had the intake for 4 months now and this problem had only accured in the last 2 weeks. At first It would drop realy low and then go back up to normal rpms, but yesterday it started stalling out on me. Im also getting normal gas milage and seams to have the same amount of power too.
s0ldats
man....i have the same problem....i haven't been able to find a fix yet... the problem is kinda sporadic for me and only happens sometimes...random..
enyaw13
Yeah that happens to me too...
I took out and cleaned my air filter and that seemed to help a bit...
any other suggestions?o2 sensor?
JJ240
Car: 95 white 240
I have pretty much the same problem. Only really noticed it after installing a pop charger instead of the air box. Only vacuum line i moved was the one that comes out of the side of the airbox, i put a breater on it
burgy240
Car: 2000 Q45 Ann. Edition Blk on Blk
Could it be a fuel filter problem at all???? just a thought
Ajax
Car: 1991 240sx SE
2010 Mazda 5
Mine is doing the same after being "fixed" by the local dealer. Last time they just reset the idle speed, but now that its happening again, I'm wondering if there's a bad seal.
Nismo_Freak
Car: 89 Nissan 240SX
IAC Valve... clean it out.
JJ240
Car: 95 white 240
Where is that located?
Phantom
You guys ever thought of bad gas. It has been a huge problem for me too and I use 92 octane but what I suggest is driving your car till almost all the gas is gone like on E with the light on and then go ahead and fill up once with super. I know its expensive but just try it and then add fuel injector cleaner if you dont have a turbo that is. after that go ahead and red line it in all five gears and if automatic just down right floor it. This will also pump more fresh gas in and clean the injectors. After a few days of this type torture to your car it shoud go away. Oh and if the check engine light doesn't go out take it to discount auto parts and have them do a code check to see if it will turn off, because it wont turn off automaticly. Also if its been a while the EGR valve may be damaged and possibly needs to be replaced.Well guys I hope this little bit helps but if it doesnt drop me a line.
s0ldats
Phantom wrote:You guys ever thought of bad gas. It has been a huge problem for me too and I use 92 octane but what I suggest is driving your car till almost all the gas is gone like on E with the light on and then go ahead and fill up once with super. I know its expensive but just try it and then add fuel injector cleaner if you dont have a turbo that is. after that go ahead and red line it in all five gears and if automatic just down right floor it. This will also pump more fresh gas in and clean the injectors. After a few days of this type torture to your car it shoud go away. Oh and if the check engine light doesn't go out take it to discount auto parts and have them do a code check to see if it will turn off, because it wont turn off automaticly. Also if its been a while the EGR valve may be damaged and possibly needs to be replaced.Well guys I hope this little bit helps but if it doesnt drop me a line.
i haven't redlined my car yet (scared) :D, but i get the highest octane i can buy around here (93)... gonna try cleaning the iacv and egr.
s0ldats
is the iacv the one under the intake manifold towards the firewall? if so, how do i get that thing ouT?? is it the actual unit that i clean or do i clean the plugs that go into it?
