1. Whenever I come to a stop pressing the brake and the clutch, the tach drops all the way down and the car studders and often stalls. Gets worse if I was just accellerating before i breaked.
OK, does the idle return to normal if you release the brake pedal? If you rev the engine a bit, does the idle return to normal? Need some more info...
2. I have a fluid leak that I can't pinpoint. Even after Gunking the engine the oil gets sprayed around te whole engine bay by the fan or belt. The leak is slow but I see no difference in any of the fluid levels over the past 2-3 months.
It's engine oil, right? The only thing I can think of is that somewhere on the front of the engine, you've got a leak (I know that really helps, doesn't it
). Dealers can put some luminescent (sp?) crap into your oil and then after driving around for a while, track it with a black light...you may want to get this done if the leak is severe.
Also there is a squeal when I turn the wheel which seems to be related. (it only squeals on right turns).
:thinker Loose belt on the p/s pump? How do you know it's related? If it is, then it may be p/s fluid that spraying all over the engine bay...can you confirm the fluid type?
John
