W O T »
https://forums.nicoclub.com/w-o-t-u75991.html
Tue Aug 18, 2009 3:31 pm
I had a problem with my car stalling out on a warm startup, give it a little gas to keep it alive for 2 seconds on startup, and it would run and idle fine, just needed to have your foot on the gas when you turned the key.
I wasnt throwing any codes, but I cleaned the throttle body, didnt help
Then I removed and cleaned the IACV (the $350 part you bought) and changed my spark plugs, car idled fine
If you havent already boughten the part, try cleaning it.
And ps, I can remove the IACV in 5-7 minutes, why 2 hours labour? you remove the intake arm, then there it is.... 2 phillips screws, harness clip and its out....
