Q45tech wrote:Measure the fuel rail pressure for 10 minutes after shutdown and the cranking and short term to run.....................very accurately in second increments.
Pressure may be bleeding down too fast and not meet the 20 psi prior to start.
I'll go to work on measuring the fuel pressure.
goody90q45 wrote:kdonn wrote:.......I was able to get the o-ring to fit but there maybe a slim chance there is a gap.......
If there was a gap you'd know it since there would be an intolerable smell of gas in the passenger cabin as you drove.
Are the fuel pump connections inside the tank tight? Is there any scorching on the FPCU socket or connector possibly pointing to a bad FPCU?
No fuel smell. I'm going to get a new o-ring and pull the pump to look at the connections. I may have loosened some connections getting the pump back into the tank. i'll also take a look at the FPCU for scorching.
Thanks for the input. I'll post results.
