Hello all,I am new to posting but have used the site for other help. I can't seem to find anything on this though. I have a 92 KA24de with a manual transmission, swapped into a 90 body. When I start my car in the morning, it likes to stall unless I give it some gas for about 5 seconds. Then when I come to a stop, it wants to stall there too. Once the car has warmed up for about 5 minutes it is fine as well. (Now keep in mind that I am in FL where the temp isn't getting much below the 75 mark.) This is when the idle screw is more than half way in. If the screw is 3/4 or more it is fine. Does it hurt the engine internally if it is open that much? If so, what does it do? Another thing with the screw, when I try to adjust the idle with the tps harness disconnected, it will not adjust to anything below 900. Any help would be much appreciated. Thank you for your time.
Modified by 2nissan240sx at 8:19 PM 10/31/2009
