mortimer9 wrote:I tried to access Phatg.20.net and downloaded the manual 3 times but so noway to bring it up.How does one do a (MAF) swap. Prices on new run 500.00. kevin
I'm PC challenged (old f@rt) but I do know that you'll need Winzip to unzip the file before using it. Unzip it one time and save it and you're set to go.
Removing the MAF should be simple. On the G50 (should be very similar on your Y33) one end is attached with 4 bolts to the airbox lid and the other end is hoseclamped to the air intake tube. By swapping I mean you need to make friends with a local 97-99(?) Q owner or meet up with a NICO member who's willing to let you borrow the MAF from their car for a couple of days while you test drive.
