Stalled seats and right rear running light.
MinnyQ
Car: '95 Q45
Two questions:
'95 Q. The driver's seat works in every direction except forward and back. It moves maybe a half inch, coming and going. It behaves like something might be jammed in the track, but I can't see anything. Is there some way to access the tracks that I don't see, or is this a blown motor? (And if its blown, why does it move even a little?)
Second: The right rear running light is out. Do I have yank out the CD changer to get to this thing?
Thanks.
CrimsonQ
Car: Purple People Eater
rear light, pull of plastic panel part behind it.
please dont double post _
MinnyQ
Car: '95 Q45
Sorry for the previous double post, I was re-re-re-re registering. I should have been more clear. The '95 Q has a red running light on the right rear quarter panel approximately at the same location outside as the CD changer inside. How do I change the bulb ... or don't I?
Also, as I say the drivers seat now only moves maybe an inch forward and back. What does anyone think? Motor shot/ Jammed? Again ... access?
goody90q45
Car: 1992 Infiniti Q45 (sold)
[QUOTE=MinnyQ]The '95 Q has a red running light on the right rear quarter panel approximately at the same location outside as the CD changer inside. How do I change the bulb ... or don't I?[QUOTE]
Put a padded screwdriver between the light and the body panel at the rear of the light. Gently wedge the light forward about 3/16" and it will pop out. Don't wedge the screwdriver to the rear as you may damage the paint. Good luck.
DrewQ45
Car: 1990 Infiniti Q45
MinnyQ wrote:Two questions:
'95 Q. The driver's seat works in every direction except forward and back. It moves maybe a half inch, coming and going. It behaves like something might be jammed in the track, but I can't see anything. Thanks.
Probably something jammed in the track as you suspect. Same thing happened to mine. I pulled the seat out (4 bolts and a plug), cleared the jam and re-greased the track.
66mgb
Car: 1992 Q45 Modified w/ NICO Goodness
McDonald's french fries petrify in aproximately 1 week. That could be the culprit...
MinnyQ
Car: '95 Q45
I considered the McDonalds Effect. In my case it could be Milk Duds and curly fries. I'm doomed!
Do I need special tools to pull the seat out? Its tough enough just to SEE under it.
