Stall???? ok maybe not....
pimpgixxer04
Car: 2006 infiniti M35x
alright first of all i just want to say hi to all my new brothers and sisters of the 240 world...i just recently bought my first 240 its a 91 SE...i bought it from a guy who took very good care of it , even though its kinda rice..but im in the process of fixing it...anyway....so this problem just started...it started out just when i turned on the car i would have the hold the pedal so the RPMS would not drop below 700 and stall out...then it would warm up and be fine...well as of a couple days ago, the car started to stall whenever coming to a stop, then i wouldnt be able to start it back up for at least 10 minutes...i searched but could not find a definitive answer...thats why im asking again....so today when i got off of work i went out and i sprayed my throttle body and MAF ( at least i think its the MAF the thing thats attatched to the air intake? ) if not please correct me....anyway like i was saying i sprayed them with cleaner and wiped them down and it helped a bit but my car still seems like it wants to stall...can anyone point me in the right direction...at first i thought it was my fuel filter or pump....i replaced the filter and it didnt help...about to replace my pump but i know pumps are usually broke or they're not...not usually intermittent....someone please help me...thanks in advance...
oh and i still have the ka24de in it...its also got a no name intake and a custom POS exhaust...thanks
Modified by pimpgixxer04 at 12:29 AM 5/30/2008
pimpgixxer04
anyone?
Axel Grungy
Car: 2001 G20 5spd
check the connection on the coolant temp sensor. Mine was gummed up and was giving me the same symptoms. Should be around the thermostat IIRC.
pimpgixxer04
OK WILL DO!!! thanks
