stainless steerl brake lines warning
Fenvy
Car: 2005 350Z Base 6MT
skatanic28
Car: 96 240sx
if this is true for all ss lines...i would think the 240 community would have a lot of first hand experience with problems like that due to the number of z32 swaps with ss lines. my ss lines should be getting to my house today...so i hope the problems not that severe.
i2ice4m3
Car: COUNTERSTRIKE!
i am enlightened
Fenvy
what he said does make SOME sense
SoCalS14
Car: My car...duh
Wow...mine were DOT approved, but now I have to work in an inspection schedule for them...I guess I am a fool, i thought they were like "bullet-proof".
wangless
Car: '02 MBP WRX
interesting...
Bluefire
Which is why the technafit lines that SPL sells are great since they have an outer covering to protect the steel braids. Hehe free promotion for SPL!!
-Bluefire
Nismo_Freak
Car: 89 Nissan 240SX
Yes, just to clarify... our lines do have an outer protective covering to prevent dirt from prematurely wearing the line.
In response to this guy's claim that the lines are "dangerous", just keep in mind that with 2 to 3 years of track usage, hard daily driving, and alot of milage you need to replace items as necessary.
Nismo_Freak
skatanic28 wrote:if this is true for all ss lines...i would think the 240 community would have a lot of first hand experience with problems like that due to the number of z32 swaps with ss lines. my ss lines should be getting to my house today...so i hope the problems not that severe.
Why because of high line pressures? The fault isn't withen the line pressure, it's withen the line's design. Some are better than others.
Nismo_Freak
Bluefire wrote:Which is why the technafit lines that SPL sells are great since they have an outer covering to protect the steel braids. Hehe free promotion for SPL!!
-Bluefire
Our lines also have correct length, this prevents the 2nd common cause for line failure and thats inadequate movement causing binding friction.
Nismo_Freak
When you think about it... which would you rather have.
New Stainless Steel Braided Teflon Line w/ Covering
or.
OEM Rubber Lines (that are 6 - 15 years old)
From the way this guy is rambling on and on I think if a rock or piece of road debris hit his OEM lines and ruptured it he would be out spouting off about how we need brake line shields.
WeldingHank
Car: 1989 240sx CA18DET
mine are incased in a plastic tubing :-D
i2ice4m3
Car: COUNTERSTRIKE!
so what makes the crimped-on fittings weaker on the SS lines than oem rubber lines?
Nismo_Freak
i2ice4m3 wrote:so what makes the crimped-on fittings weaker on the SS lines than oem rubber lines?
His opinion.
i2ice4m3
Car: COUNTERSTRIKE!
:Werd
Tai Mai Shu
Oh well...If its online it must be TRUE! :pface
i2ice4m3
Car: COUNTERSTRIKE!
so those herbal pills CAN enlarge my pen15 by 4 inches?? w00t
Nissan-S14
Car: 95 Nissan 240SX SE
I have earl brake lines am i excused!
S13ChucKAT
Car: asd
ive had SS lines on my old 200sx, with the nx2000 upgrade. and i abused the hell out of them.. they held up perfectly, and 2 years later, i took them off, sprayed them down with brake cleaner, and they still looked brand new, with no immediate show of brake line failure. no leaks.
