Postby
elwesso »
https://forums.nicoclub.com/elwesso-u5248.htmlSun Aug 03, 2008 2:08 pm
the point i was trying to make is just assume that you cant get any aftermarket parts for VH45s unless they happen to swap over from other nissans or its an adapter plate.
Postby
Bart »
https://forums.nicoclub.com/bart-u9043.htmlSun Aug 03, 2008 4:42 pm
If you must use stainles steel go for 321 grade, very expensive but crack and corrosion resistant.I would go for thick wall steam pipe/mild steel, 3mm thickI would use TIG not mig if you can help it.
