stainless-steel-brake-lines-q50-q60
One of the economical brake upgrades for your Q50 or Q60 would be replacing the OEM rubber lines with Stainless Steel Brake Lines which improve the pedal feel, help improve braking performance compared to the soft stock rubber lines and longevity as rubber lines will deteriorate faster.
The PTFE hose has an extruded PTFE core, with an outer stainless steel braided wire covering, while the abrasion resistant rubber coating on the outside gives added protection from flying debris; it also gives some abrasion protection from the line rubbing on suspension parts, in extreme braking conditions, with full compression (most movement of line).
DOT certified, which insures that they meet or exceed the DOT certification that is outlined in MVSS-1006 specifications.
Vechile Fitment:
2014+ Q50 Sport or Non-Sport
2017 Q60 Sport or Non-Sport
