I went down to the local Earl's distributor today . They had off-the-shelf stainless steel brake lines available for about $19 each. These are simple lines, with the correct-sized fittings on each end, that are very near the same length of the stock lines on the car.If you look at your lines, though, you'll see that each line has 3 intermediary fittings along the length that allow it to be secured to the frame to reduce the loads on the line. The rep said this is not a concern with the SS lines, since the outer sleeving can easily support the weight of the entire part without sagging or stressing of the inner rubber/teflon sleeving. BUT, the lines can be custom made for about $30/line to match the factory lines if desired.Here's where it gets interesting. I then asked him about group buys, and he said that if I can move enough sets I can get full brake sets for about $50/set for off-the-shelf, or $75/set for custom.
Check out the Earl's site--apparently these lines have passed all DOT lab tests. Site does NOT say lines are DOT-approved. Also, the site implies these will work on models '90-'95.
http://www.holley.com/HiOctn/P....html
Give me a head count if you guys are REALLY interested. OH, and they have a product VERY similar to speed-bleeders for about $10/pair...I can pick up a bunch of those too for anyone who wants them. I've had them for about a year, and they're still dry and clean with no signs of leaking.
You guys let me know. My brake seals arrive tomorrow. I should have them all back together this weekend with the new lines, and I will update you on how they install and perform.
