stainless oil and water lines for rb26
StricNyne
well my metal lines for my turbos are fubared so i was looking into doing this for my car http://cgi.ebay.com/ebaymotors...wItem
or
but i need to do a T fitting for the twins, also i am concerned about the water lines i know i dont NEED to run them and i dont want to but when i upgrade i would like to have them also for the oil and water drains can i justt the drains to one bung
OR is there a premade set that dosent cost , arm, leg or left nut
Sil240
Car: Nissan S13 "The One Cam Wonder"
Yo I thought that your getting the ones from that guy???
That's the same kit I have for my turbo.Really good fit.Just the feed line is hella long. (been talkin to my cali people) lol
tjmhillz
Car: 2001 Lexus IS300 Turbo
this is carlos, ya theyhavent gotten back to me yet but those look good and like i need and WAY cheaper
Shocker
Car: 89 240sxHB rb26/30
I got mine all made locally so I could get exact sizes and know that everything will fit properly.
StricNyne
share sizes !!!
Shocker
well through my 35r, I run a 1/8 NPT to feed it oil, 1/4 NPT to give it coolant and to take it away. Then the drain might be 3/8 NPT its big. I tapped my block to standard at all places as well. Metric fittings are an *** raping.
heres a pick all all my fittings at the housing. THEY ARE A ****ING ***** TO TIGHTEN AND REMOVE. I wish my housings were held down by v-bands not bolts, they get in the way.
Sil240
Hey what dimensions/specs was the water drain in the block stock?
My motor is put together and in the car, I'm not trying to tap the block like that.
StricNyne
tap into the heater core hoses man !!!! i did it on the celica i turboed it should be uber simple with a big single
Sil240
Yo check this out.Call them.This is where your boy was gonna get those lines from.
http://takamotorsports.com/
The only thing is that I don't have them hooked up.I might hook them up eventually if need be, but being down here in FL, I didn't see any use for it.
But I found a post that helped me out:zerothread?id=280833
It was exactly what I needed."The search button worked for me!!!!" According to the thread its M14 x 1.5
I just remember that I searched for this a while a go so that I could find a bolt to plug it. Duhh....Blonde moment, its all my ex girls faul. lol
For anyone else interested, I just found this info:
"Oil Feed at Block: M12x1.25Oil Return at Block: 3/4" BSPT (3/4" NPT can work)Coolant Return at Block: M14x1.5"
Modified by Sil240 at 9:19 PM 12/28/2007
BoostFab
Car: S13cp, S13fb, S14z
i have made the oil feed adapter in the past for rb folks, to be use with a AN-4 or AN-3 feed line. email me if you need one; i might have an extra one.
i had post on here may times; the feed size on the block is M12x1.25
StricNyne
**** the feed thread on block is m12x1.25 i bought ****ing wrong size **** is that for oil only what is water ?
http://cm.ebay.com/cm/ck/1065-...16440
http://cm.ebay.com/cm/ck/1065-...83947
i bought both of those GOD DAMMIT
i swear its one thing after another ****kkkk at least now i have an idea how i am going to do my oil lines with that t, i just gotta figure out oil return for twins, and all of water lines
once i get this all figured i wanna stiky it
gawdzilla
Car: none
StricNyne wrote:**** the feed thread on block is m12x1.25 i bought ****ing wrong size **** is that for oil only what is water ?
read up like 2 posts. sil240's post.
StricNyne
so i just need an adapter, noot too much of a biggy but water lines still pissin me off imma take pics and post em up
StricNyne
****ing water setup on rb25 is gunna be a *****
BoostFab
if you're running the stock turbo; why not use the stock lines; i don't see a big deal with moving to stainless braided lines on stock turbo. just a waste of money. i still have the stock water lines if you need them.
StricNyne
i am willing ot run stock lines i just dont have them, and i am running a custom intake that cuts down on a ton of the cooling lines, and since its a rb25 my intake dosent have the front turbo water return line its all fubar lol, thats what makes it sooo tricky
Modified by StricNyne at 9:59 PM 1/15/2008
BoostFab
i just sketched this up in a minute; if you decide to want to use the stock water lines, you can have mine (free, you pay shipping)
StricNyne
ahh good pic, but thats a 26 block i dont have that rear water return since i am on a rb25, BUT there is a water port on intakemanifold i think i could use
BoostFab
that is a picture of an rb25det block; so you're saying yours never had that small port
StricNyne
yeah thats weird i dont have that rear port
StricNyne
i got the big one i dont have the small water nipple tho
BoostFab
now you know where it should go; it shouldnt be too hard to plumb in the water line; just use a little creativity.
Bluefire
The RB25 has a single large port on the rear of the block. From the factory there is another T piece with a small line that goes to the turbo.
If you can weld aluminum you can easily make a T piece with some piping
-Bluefire
Bluefire
As for running the steel braided lines, you will need two adapters one for oil, one for water. Oil should 12x1.25mm, water I believe is 16x1.5mm (Sr20's run the smaller 14x1.5mm). Then from the adapters you run a tee like this: http://www.holley.com/925106ERL.asp or http://www.holley.com/926106ERL.asp . I would run the -6 for waterlines and -3 or -4 for oil lines. Then just run your steel braided lines to the turbos.
I suggest you pick up an earl's catalog. You don't have to use earl's brand stuff but the catalog helps to design your plumbing system...
-Bluefire
StricNyne
ahh ok i have a a better idea now, once i confirm sizes i wil get it all down and ask to get it stickiedm i will let u know progress tonight
also boostfed shot me an estimate for 08861 shipped and i will send u some money for those water lines shippin plus a lil xtra for yer time
Modified by StricNyne at 1:35 PM 1/16/2008
StricNyne
bump i got oil lines in today, and i got them figured out which is plus, i think i kno where water feed is, and i can do the lines for them just water return actual lines i need, i got a way to get them returned, i will compile a list of length, fitting size, and yadda for a possible sticky !!
StricNyne
ok the block oil port is 12x.1.25 where can i get a 1/8npt to 12x1.25 adapter the 1/8npt is the T fitting that goes to each turbo
