deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Sun Mar 07, 2004 8:16 am
I have not yet been able to compare the ka24de/ka24e valves LT_Z. I will post up as soon as i do. Yeah, solid lifter conversion, works very very well. It does give more noise, but i found performance benefit from this alone (pdm c.404 cam hydraulic vs. solid). Many cam regrinders can work with your cam, if they have to create a custom profile it can be expensive, but if they can find a grind they have done before that will work it is very cheap. You will want to have your rocker arm ratio (1.422), valve train type, stock cam specs (as well as what reground profile you would like) to tell the grinder first time you talk to them.
There are quite a few more things you can do with the valve train. Mostly custom stuff but if your interested, i know a few tricks.
SSS, How long overall did your adjusters end up? if i recall correctly, mine are about .715". They are shorter, and have more clearance in all directions than the stockers. If you having a clearance problem with the large lock down nut, you can buy ones that use a head smaller than 5/8" and grind the height down. I use the hardened larger lockdown nuts, and have checked clearance on truck and 240 valve covers witht the same results. I have just about everything else for a stanza but the valve cover, haha.
Post those pics when you get them.
