Stainless Brake Line Kits
Nismo_Freak
Car: 89 Nissan 240SX
We offer our Technafit Brakes lines for the S13 and S14 for only $75 for both front AND rear lines!
Contrary to what some people say these brake lines work with the Z32 and R32 calipers as well. We know this because we have used them on a S15 which as many people know comes standard with the same Nissan 4-Pot caliper as the Z32, R32, JDM and Euro S14, R33 GTST, and the R34 GTST.
We have them in stock and ready for shipment!
EMAIL: [email protected]Please mention your from NICO to recieve the special pricing :)
SPL PARTS350A Old West DriveRound Rock TX 78681
Toll free order/support line (USA only) 1-(866)-SPL-PARTDirect Line: 1-(512)-289-3012Fax: 1-(512)-692-1977
rico05
Car: 1992 RMS13 w/ CA18DET
Dang...where was this 4 weeks ago. THose are a way better deal than the Goodridge ones I bought!
Nismo_Freak
rico05 wrote:Dang...where was this 4 weeks ago. THose are a way better deal than the Goodridge ones I bought!
Yeah it's a good deal :)
93RPS13
Car: Cars, Girls, Cars, Food
so the line will work with S13, Z32 R32 calipers? Thanks
Nismo_Freak
93RPS13 wrote:so the line will work with S13, Z32 R32 calipers? Thanks
Yep... although the fittings are alittle different we have used our S15 for a test dummy, and I can report that we've had no problems at all with using the 240SX lines on S15 brakes, which use the same 4-pot calipers as the R32, R33 GTST, Z32, etc.
p00t
!@!#@#@@ arg same here, i missed the $80 russell SS line set at groupbuycenter.com and i didnt want to pay 100+ for em, so i skipped it during my brake overhaul.... now i am mad!
PalmerWMD
Car: 2004 350Z
SS brake lines are a must for a proper set-up.
I have them on my current Q and had them on my last Q.They add reliability and improve brake sytem reaction speed.
Fred...:)
toledo240
So are you saying these ss lines will fit the s13 z32 brake swap but dont have the exact fitting for them?
float_6969
SS lines rule. I couldn't believe the difference they made! Also, I used the 240 stock rubber lines on my Z32 brakes for almost a month with no problems. Just MAKE SURE to put NEW copper gaskets on it and you'll be all set.
Phax
Car: Control dynamics
float_6969 wrote:SS lines rule. ...
:Werd
Jookmasta
do they work on the factory s13 calipers?
float_6969
they'll work on the stock S13, s14, and Z32 brakes.
sr20power
Car: S14 Zenki
i'm with toledo240, i'm interested in the ss brake lines....i'm going to swap out the caliper for the z32......should i wait until i get the z32 calipers and then make the order for 240 to z32 caliper fittings? if there isn't any problems then i'm ready to order......:asmile
astron
Is this deal gonna last a while? I want to see how I like my new brake setup without them before I order...(plus i've got too much work to do already..new brakes, wheels, shocks/struts, strut tower bar, sub boxes to build, probably some more stuff...hehe...busy christmas break!)ast
Nismo_Freak
float_6969 wrote:they'll work on the stock S13, s14, and Z32 brakes.
sr20power
Car: S14 Zenki
man you must be getting frustrated ......i know that it will work on the stock s13,s14, and z32 brakes, from reading your many qoutes of " they'll work on the stock s13, s14 and z32 brakes...
but are the s13, s14 and z32 brakes all have the same fittings?if i were to buy the s14 brake line kit and later change the calipers with the z32 (300z), are the fittings the same or should i wait until i get the calipers first?
thanks....sorry for the repeatitive question but just want to make sure (i called spl and they weren't really sure and told me to talk to you, before i put in an order)
Nismo_Freak
astron wrote:Is this deal gonna last a while? I want to see how I like my new brake setup without them before I order...(plus i've got too much work to do already..new brakes, wheels, shocks/struts, strut tower bar, sub boxes to build, probably some more stuff...hehe...busy christmas break!)ast
yes :)
float_6969
sr20power wrote:man you must be getting frustrated ......i know that it will work on the stock s13,s14, and z32 brakes, from reading your many qoutes of " they'll work on the stock s13, s14 and z32 brakes...
Technically, no, they don't have the same fitting. The stock S13 and S14 brakes us what's called a banjo fitting. The Z32 caliper uses what is called a inverted flare fitting. But because Nissan is cool, both use the same thread diameter and pitch so you can use the Banjo fitting on the inverted flare, you just need to make sure that you put new Copper gaskets in.
sr20power
Car: S14 Zenki
thank you float.......for clarifying it for me.
now i just need nismo_freak to give me the okay on the infothen i'll put in the order.......
sr20power
Car: S14 Zenki
unless float you have the spl stainless steel lines or work for spl?
Nismo_Freak
Basically what Float said... all you need to change from the OEM calipers to the Z32 calipers is a small copper gasket to insure a tight seal.
So yes, they will and do work on the Z32 calipers.
toledo240
small copper gasket? does it come with it? where do you get that?
Kinesthesia
Just to be sure... since they fit S13 calipers, then they'll fit Q45 calipers ?
sr20power
Car: S14 Zenki
well i just put in the order......total $85 not bad considering that my friend bought ss lines for $140 (bf goodrich)
nismo_freak you know how long they will take to deliver?
Nismo_Freak
If they are in stock (which they should be...) it'll be out at 4pm today via UPS more than likely which is 3-5 days
float_6969
Kinesthesia wrote:Just to be sure... since they fit S13 calipers, then they'll fit Q45 calipers ?
Yes...
sr20power
Car: S14 Zenki
nice i just got the tracking # for UPS.....sweet they'll come by on tuesday, i can have them in before the autocross that weekend.....:asmile
thanks for the info nismo_freak
float_6969
Damn you people in Cali with your autocross meets in December!!! My last meet was in October for pete's sake! Grrrrr....
sr20power
Car: S14 Zenki
last meet was in October??!!!! damn, i was complaining that a meet once a month wasn't enough.....but then again i just started autocrossing in august, so i'm pretty excited about it (just wanna drive my girl)
man hate to be in kansas.....
Nismo_Freak
We have a drift event Jan. 21st hahahha.
Texas > Kansas :D
