Not a good idea on the X (AWD) models. Your manual addresses this topic.
The Nissan/Infiniti ATTESSA AWD system is sensitive to front-axle/rear-axle rotational mismatches and will wear faster and potentially misbehave or be damaged, depending on the degree of mismatch.
Please stick with identical wheels on all four corners - even identical tires, since rolling diameters of "identical" sized tires can be different. This is probably not as strong an effect, but why take risks?
There are a number of threads on this topic - a Search will help explain.
Z
