a.blanco0905 wrote:He says that as long as the wheels have the same diameter it will not hurt neither the diffs or the AWD system... i.e. do not put a 20" wheel in the rear and 19" in the front on any AWD system but you can have 20" in the rear and in the front even if they're not the same width.
No. Not the same thing. Plus, the Audi and Nissan systems are not comparable.
If you put different width wheels on a car, even with the same diameter wheel, you will have to get different tire sizes (with differing aspect ratios) to try and get the same
rolling diameter.
And you will fail to make it match well enough for the Infiniti system! The reason is that static and rolling diameters for different sized tires are
quite different.
So, what might measure "close enough" on a lift, may well have slightly different rolling diameters when the car is at speed ... for an extreme example, ever see what happen to the rear wheels of a nitro dragster? Just the act of applying torque and spin causes these soft tires to expand in diameter by a
lot.
Of course, I am not trying to compare that effect to what happens here, but just pointing out that this is not as simple you might think!
And, the results of potentially damaging the ATTESA sysem on your Infiniti X models in this manner, will not be covered under warranty - the manuals are explicitly clear about the requirement. Please see my extracts earlier in this thread!
Z
