Staggered Wheel Widths and Tire Rotation
BigAlAtlanta
Car: 93 Q45 (new to the stable), 94 Q45 - RIP, Mighty Blue D21 89 Truck, 66 Impala SS Conv, and 09 VW TDI
I'm considering finally getting rid of the old Pie Pans and moving up a few inches in wheel sizing. I've noticed that several people are running larger width wheels in the back. Do you just have the wheeels balanced and not rotated?
Are there any issues with this or benefits?
Just hoping to understand before I make a wheel decision. Thanks for all the other wheel and tire info.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I run staggered tires and you can rotate them side to side but not front to back. Overall, I dont recommend staggered tires for Qs, as 245-45-18 all around is spectacular.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
BigAlAtlanta wrote:Are there any issues with this or benefits?
Read Q45tech's posts on suspension, vehicle loading and spring rates. You will learn that staggered tires are an affectation, not a performance enhancement, without changes to the suspension.
Rex
Car: None
elwesso wrote:I run staggered tires and you can rotate them side to side but not front to back. .
Not all will allow for even side to side rotation as some are marked "this sidewall out".
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Those would be assymetric and directional.
DoinkMobb
Car: 1994 Infiniti Q45 Green/Tan
1996 Subaru Impreza 2.2L wagon
I couldn't imagine a stock or nearly stock power level Q needing big rubber out back. Maybe if you ran very little camber, stiff rear suspension and a huge rear sway bar, it would necessitate wide rubber to keep the rear end on the road. All it would do on a stock Q would be to promote understeer.
