Am I allowed to ask why you want taller tires? Are you trying to fill out the wheel well without dropping the car? Is it uncomfortable to get into at the stock height?W661335PF wrote:I'm not looking for wider, but taller tires. Should have mentioned this, sorry. So the question remains, will this set-up work????? Or possibly the basic 225/55/17 size.
I'm not sure a 235/55 will fit in the front though. A 245 or 275 looks too much like an over-sized truck tire on on Toyota truck IMHO.
Will the 245/55/17's actually fit on the front end? The 245's, according to my calculations, are actually about 1.3 inches taller and 1.1" wider. The distance between the 215's and the arm is about .6 inches, and dividing the 1.3 inches by 2 would make it a tight or impossible squeeze. Given this, my thinking is that the tire will not fit beneath the arm just above it on the sedan. What do you think?tollboothwilley wrote:You could fit 245/55/17 all around, as i said. The difference in height is 0.4" and a wider tire.
235/55/17 is almost exactly the same as the 215/60/17 in overal diameter.
I'm using 225/55/17 on mine right now...
I'm both trying to fill out the gaping wheel well gap w/o doing surgery (i.e. dropping the car) with maybe even hoping for increased mpg since I drive like an old man in a hat (get 22-25mpg city/highway in a very mountainous terrain). I might not get the 2nd wish, but filling out the wheel well will be a definite plus. I've decided not to go staggered as you recommend for the reasons you site, tho. Any further thoughts-- THANKS!Sentientbydesign wrote:
Larger overall diameter will definately effect performance. MPG is debatable. It depends largely on what speed you go and if you have an auto or manual.
Figure it this way. Every size larger you go (with the same aspect ratio) will raise the car .21". I would definately advise against staggering if you're reason is for height though. Not being able to rotate front to back is horrible.
