CMG wrote:Thanks for the help. What I mean by stretched is that if I put a 205 on a 7" it will have a normal sidewall, while on an 8" it will pull the sidewalls back a bit and change overall diameter. The reason I asked about that is for clearance issues with the fenders.
What offset are these wheels that will cause you fender clearance issues.
To find the actual height of the streteched tire, you're gonna need to know some basic geometry than and solve the right triangle created by the stretched tire for the triangles height.
When you get this height, multiply it by 2 and add the wheel diameter. This will give you the overall diameter of the stretched tire.
