I think they were saying don't put wide stupid tires like nankang, nexen, or something like that. You would be better off buying a better tire in skinnier size then trying to go cheap on the widest possible tire. You are also right about the contact patch. The tire has to fit the rim properly, like a tire to wide for the rim.unlearning wrote:I hear things like wider wheels=more grip, and better handling. Then read articles about how wider tires don't necessarily mean more grip.
By this logic, if you are only "upgrading" the size of the rear tires, you will have essentially "more grip" on the rear making under-steer as opposed to the kickout and over-steer of a drift type situation.hai1206vn wrote:supposedly wider rear tires should help against the rear kicking out. If you only upgrade the rear, the front will slip more --> understeer
As far as having wider wheels in the front, in theory it makes just as much sense as having wide wheels in the rear. Think that basically you can only have so much traction in a mechanical type situation. If having a wider wheel in the rear is going to give more traction as far as accelerating in a RWD vehicle, upgrading the front tires to a wider size is going to do the same, just in the aspects front wheels are used for in a RWD application, steering and breaking.Kalypso123 wrote:what benefit do you get from having wider wheels in the front,also to the OP -
stiff rear suspension and soft fronts - gives more aggressive handling and makes it easier to drift and kick out the rear.
I read that in an SCCA article about suspension tuning. let me look for it.
Shoot for roughly 500~ HP. On a lower scale even high 300s to low 400s if I went with my KA in the meantime. Didn't ever think I'd really need anything larger than a 17".Slappy wrote:Wheel size should depend on HP. If you have a 90hp car , and you have 19" wheels......
Oops yea.unlearning wrote:And did you really mean -30 offset? or +30?
No.Slappy wrote:Staggerd = looks
Same all around = faster lap times
People primarily run wide wheels for the look.unlearning wrote:What I do know is that lately, and when looking around, people have been trying to run as wide a wheel as seems feasible. Why, no definitive answer has been given to me. So please slam me, .
Wrong.Nismo_Freak wrote:
No.
You would think tires and wheels that big on a "relatively slow 240" is useless. I think 16x7 and sticky's will work just fine.Nismo_Freak wrote:If you want good handling in a relatively slow 240SX then I would opt for 17x8 or 17x9 all around with a 235mm tire.
Um, you size tires for the dynamic weight load. There is no cookie cutter methodology to tires. Increasing spring rates, track, ride height, etc. all effect what is optimal for the car.Slappy wrote:Depends if its a RWD , FF or AWD. Use staggerd on a FF or AWD and it will handle like ****. Some RWD cars come from the factory with staggerd fitment but when you only have 150hp your just draggin extra weight and rubber around that you cant use. The only real way to answer your question is to try different size wheels and tires and come up with your own conclusion like i said before.
I'm looking down the road. The 17's allow brake upgrades larger than Z32's, and also have a much larger options in regard to fitment, track, and tires.Slappy wrote:You would think tires and wheels that big on a "relatively slow 240" is useless. I think 16x7 and sticky's will work just fine.
What exactly do you mean by "relatively slow". Stock or like <500hp?Nismo_Freak wrote:If you want good handling in a relatively slow 240SX then I would opt for 17x8 or 17x9 all around with a 235mm tire.
What exactly do you mean by short and fat? 325/50/15?Nismo_Freak wrote:If you want pure performance for a 240SX for something like Auto-X I would run 15's with a fat, short tire
Something with near stock power.unlearning wrote:What exactly do you mean by "relatively slow". Stock or like <500hp?
If you go turbo on the KA and make lets say, 300whp, then you are going to want something like a 255/40/17 Front and 275/40/17 Rear.unlearning wrote:Let's say for time being, and understanding that there is no "cookie-cutter build" more-or-less, if I was looking to completely rebuild my KA and throw a turbo on, what would be a good starting point for feeling out tires and wheels as far as size is concerned? Assuming I have coilovers, and a few bars installed. I'm definitely not opposed to 15s or 16s, just thought that later down the road I'd be looking at 17s anyways once the car was completely rebuilt.
Short as in the overall height of the tire. Fat as in wide to increase the load capacity of the tire to an acceptable point.unlearning wrote:What exactly do you mean by short and fat? 325/50/15?
maybe we do it, for the same reasons. I cant see how slimmer wheels will help steering tho.Slappy wrote:^Wrong
Tires are simply the medium that all the load is transferred to the ground. The size of a tire is therefor relative solely to the amount of load placed upon it throughout the dynamic motion of the car.Kalypso123 wrote:maybe we do it, for the same reasons. I cant see how slimmer wheels will help steering tho.
Thanks brosef. I actually stumbled upon that before and forgot to bookmark the site, much appreciated.
Agreed and exactly why I'm trying to take my time to fully understand things before I make decisions. When I first picked up my chassis, the sole purpose was to tear it apart and build a track car. Now after various extrenuating circumstances, It seams as though it will take me much longer to put together the funds for the track car than I had originally planned.Nismo_Freak wrote:
For now a 235 all around should work out for you.
Usually it's best to plan for 300whp and get there, than plan on today and have to revise for tomorrow.
as much as I appreciate such a thorough answer. I spent a while looking up some of the terms you're using instead of being inspired and understanding you.Nismo_Freak wrote:
Power is a variable in the equation, not the determining factorization. The assumption is that with greater power comes greater dynamic load. This is true to a point since you are limited still by the suspension and geometry. If not, a 1000whp Supra with 405mm F1 rubber would be the fastest thing to hit the pavement.
Fact is there is a limit to the amount of load that the chassis can impart on the tires. Load is what pushes the tires into the pavement, producing friction and slip angle, and the resulting steering. The tires size basically shifts it's nature in how it responds to load.
If you look at this you see the linear relation ship of steering angle and slip angle, along with the interaction of load vs. slip angle, which is a curved plot. The plot is curved based upon the tires ability to convert load and steering angle into friction (side force). The larger the tire, generally the more load it can withstand before it begins to return less of a linear response (larger being load index, not tire size). THAT is the benefit in larger tires in terms of grip. Other aspects are heat management and mechanical forces in relation to tire trail, slip angle threshold, etc.
After understanding that, you have to look at the car and understand the dynamic loads it will see. A car with a high roll center, alot of static weight, and a narrow track and wheelbase is going to require SIGNIFICANTLY more tire to handle the same as a car with more preferable attributes.
You could have a really fast straight line car, but it's tire requirements will never match that of braking and handling. Ergo the fallacy of associating a direct correlation of power to tire size. It might seem as if I am doing exactly that, but I am simply trying to state it in a more understandable manner.
That is the long answer to what I suggested.
