Staggered Look
M90_NACoupe
Car: 2003 Acura TL :SOLD
2008 Altima Coupe 3.5 SE
Soo Im a really big fan of staggered sets but I do understand the slight differences in handling when it comes to a FWD. My question is how would using different offsets work with keeping the same width all around instead of having bigger rim widths in the Rear. The setup im contemplating is
20x9 +35 Front
20x9 +15 Rear
245/35/20
Coupe
Would these specs still achieve the overall staggered look without issues? I'd really appreciate some feedback as soon as possible, The deal is kinda time sensitive.
downedzephyr
Car: 09 Altima Coupe 3.5se
20x9 +15? good luck with that. expect to spend money pulling and rolling your fenders. and i sure hope you're not dropped, because you'll definitely be rubbing.
M90_NACoupe
lol I knew it would be pushing it, but I was hoping I could get it done with just a roll. And I was definitely anticipating a eibach drop in the future.
downedzephyr
if you're gonna lower, you will definitely need to pull with an aggressive offset like that. i have 20x8.5 +42 on a drop with 245/35, maxed out camber in the rear and i'm pretty close to needing to roll
M90_NACoupe
dang. Ok. Guess Ill scratch that :facepalm:
AlexM.
Car: 2010 Nissan Altima Coupe 2.5 Super Black
Someone's already pulled off 9.5 +15 so shouldnt you be able to pull of 9.0 +15? The only difference is he was running 20" vs 19.
downedzephyr
AlexM. wrote:Someone's already pulled off 9.5 +15 so shouldnt you be able to pull of 9.0 +15? The only difference is he was running 20" vs 19.
if you're referring to oilsink he had to get his fenders pulled and rolled. i talked to him about his wheels when he said he was going to sell them, but i decided against it because pulling the rear fenders would be a pain in the a** due to the rather large flat area around the edge of the wheel well. and he was running 19x8.5 +15 up front and 19x9.5 +15 rear
M90_NACoupe
Yea I really dont wanna do the whole rolling and pulling stuff. Pain in th A**. Worst case scenario would be a slight roll in the rear. but screw it.. I'll find something less aggressive.
downedzephyr
yeah. rolling in the rear shouldn't be bad, assuming you go to a place that's somewhat competent. just make sure they're not doing it by hammering it flat, that completely eliminates any chance of it being fixable in the future.
AlexM.
Thanks. Valuable information
