godzilla_753 »
https://forums.nicoclub.com/godzilla-753-u55381.html
Tue Dec 29, 2015 12:06 am
so from what I read, you have good injector pulse, and no spark.
your best bet is to download the FSM for that model stagea and trace out the inputs for the spark plugs.
If I'm looking at the right diagram the coils share a common power coming off pin 7 on the ECM/ignition coil relay. that relay also connects to the pin 72 and 4 on the ecu and should be (+). Also coming off that relay are some grounds, so maybe start with that. If all those inputs are correct you should start. Also do you have a wire going into pin 32 on the edu? When I had my swapped stagea from japan, for some reason that wire was missing, and i had a similar problem, couldn't start the car. added a pos wire there and got it running. Also not sure if I'm looking at the correct diagram so please recheck yourself.
Electrical problems are the worse, good luck !
