stage2 cams?? ka24de
fullmetal
Car: 240sx, up for sale!!
ok so this has probably been posted before but I looked and found nothing. so here it is goes any one know of a good set of stage 2 cams for a turbo charged 91 240sx running the stock KA24DE motor with about 5-7 Psi of boost? and where does it put the power at. If there is already a thread for this just redirect me and call me a newb.
Axel Grungy
Car: 2001 G20 5spd
moved to KA-T forums, you will get a better response here.
lrb_2000
Car: '91 Nissan KA-T hatch
stage 2.. like in need for speed?
Are aftermarket cams really nessissary for only 5psi?
9sec240
Car: S14.5 Turbo KA
Crower V2 cams will open up the breathing in the upper RPM range... Where your car normally feels like it falls on its face, it will continue to pull....
The amount of boost you run wont matter....
The centerlines and lobe seperation are also designed for boosted applications instead of NA to compensate for added exahaust back pressure and pressurized intake charge...
