PsYchOG35 »
https://forums.nicoclub.com/psychog35-u44998.html
Fri Mar 23, 2007 6:49 pm
One of my buddys just totaled his g35 he bought a stage 3 clutch about a week ago and was gonne put it in his car but since its totaled now no point in that huh. The clutch is BRAND NEW never been installed its a stage 3 6 puck clutch with a light 13lbs flywheel heres a full description of everything.
XTD 6 puck "MIBA" Copper Ceramic clutch is designed for the serious enthusiast with just Stock to considerable modifications.("Miba" Copper Ceramic Material is well known for AirCraft brake material.It is more Durable and hold 60% more Torque capacity than Cabontic or Kevlar Material also "MIBA" Disc grips 30% harder than Cabontic Disc) This disc features 12 high-coefficient ceramic pads for quick engagement and the extreme duty friction needed. Our specifically designed high torque disc delivers maximum holding capacity without compromise. The sprung retainer assembly boasts 6 dual springs and 6 severe duty retainer rivets, ensuring power and reliability. This XTD clutch kit fits 2003 - 2006 Nissan 350Z & 2003 - 2006 Infiniti G35 model.This XTD Stage 3 Clutch Kit Includes XTD High Clamp Long Life Pressure plate,XTD "MIBA" 6 Puck Copper Ceramic Disc,Koyo Throw out Bearing, Alignment Tool,This XTD Pressure plate Holds 30% more HP and Torque Than Stock Pressure Plate and This Pressure plate is made from ductile iron and heat Treated Which is about 20 % Stronger Than Just Stock Cast Iron Pressure plate. XTD Stage 3 Copper Ceramic Disc is designed for Ultra Racing Purpose and it Graps much harder than Carbontic or Kevlar disc also It will Increased Acceleration.However,It designed also Smooth Engagement and improved durability for Street so It won't make you difficulty on Daily Driving.This XTD Stage 3 clutch kit is Great for Just Stock or Modified Application.All XTD Racing Clutch kit Requied 500Miles Break-in Period.ABOUT XTD 13LBS CHROME-MOLY FLYWHEEL
# XTD Flywheels are made using the highest quality, most modern materials available. All of these materials are tempered Chrome-Moly Steel which are very strong yet very lightweight. The friction surface is very special. XTD uses a high carbon, Chrome-Moly Steel. This Chrome-Moly is perfect for this use. It is incredibly durable allowing the user to use just about any clutch disc material available from Stock organic to Kevlar,Cooper Ceramic and even sintered iron.XTD attaches the friction surface using Heat Treated aerospace nuts and bolts or 304 stainless steel rivets depending on the application. These are some of the best fasteners money can buy. We chose them because of their incredible shear strength and resistance to corrosion. All of XTD's ring gears are heat treated for durability. They are heated, pressed on and then secured using grade 10 fasteners.If you need more info about product or company please click " PAGE" .#
Professional installation recommended.Just buy parts from us and give to your Mechanic for Install.
# Benefit of XTD 13Lbs Performance Flywheel.Much lighter than factory steel flywheels# XTD Flywheel Works with XTD,Clutchmaster,ACT,Centerforce and any OEM Stock Clutch.# Stronger than Stock cast iron, billet steel or aluminum# Made from only the highest quality materials and CNC machined# Any street or race engine will produce more torque and Accelaration# Any street or race engine will last longer due to less stress on the engine internals.
# Perfect for Street and proofed on Track!!# Pressure Increase 15%/Torque Capacity 479ft/lbs / Hold 539HP.# Professional installation recommended.Just buy parts from us and give to your Mechanic for Install.# 12 months or 12,000 miles manufacturer defect warranty
Appilcation of XTD Racing Clutch Kit# 2003 - 2006 Nissan 350Z# 2003 - 2006 Infiniti G35
XTD CLUTCH COMBO KIT INCLUDES# XTD HD RACING PRESSURE PLATE# XTD "MIBA" 6 PUCK COPPER CERAMIC RACING DISC# KOYO THROW OUT BEARING# PILOT (BUSHING) BEARING# ALIGNMENT TOOL# XTD 13LBS CHROME-MOLY FLYWHEEL
he payed 680$ for this set up and hes asking 550$ SHIPPED. The pressure plate has scratches on the outside part of it NOTHING TO DEFECT PERFORMANCE. Plus no body will even see the outside of the pressure plate since its inside the transmission. If you want pics pm me.
