compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Sat Feb 04, 2012 9:33 pm
When I choose a clutch I don't go off of ”stages”. For example your car is mainly a dd. My first recommendation is an organic disc. an ACT organic is a very heavy duty organic material than can take a beating, but still be very drivable. Second thing is how much hp you are running. With the setup that you have may be 170-180 hp so a stage 1 pressure plate should be more than enough. The only other thing to consider is if you do dd the car, I would stay away from unsprung clutch discs if you are in a lot of stop and go or stop sign to stop sign. Also be aware that the lighter the flywheel, the higher the rpm has to be to get your car going. On my sentra I have an 8 lb flywheel and have to really jeep the rpms up there to get going. Lightweight isn't always a good thing.
