[moved]stage 2 clutch issues.
spenka
Car: 2015 Subaru WRX STI
1994 Z32 soon
i changed my clutch to a stage 2 with a 11 pound flywheel. all was good till a few days later when my clutch went really soft, i bled the system twice also changed the slave cylinder and still no clutch. the clutch is really soft, the slave cylinder wont even push the clutch fork. i used a prybar and pushed the fork which it did move in a normal manner but it was a little stiff. im thinking its the slave cylinder not strong enough to push the fork or the pressure plate spring is too stiff to be pressed by the fork. my 240sx s13 is just sitting there and not going into gear at all due the this issue. does anyone have any input to help me.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Wrong forum. Read forum rules next time.
spenka
1994 Z32 soon
p.s.- its all stock motor and transmission but with a stage 2 clutch with flywheel.
spenka
1994 Z32 soon
sorry
Reverend D wrote:Wrong forum. Read forum rules next time.
