stabilizer links + bushings for y33 1997
Qproject
anyone replace them ? It was suggested to me that I replace them.
what you guys think ?
Q45tech
Rubber bushings get attacked by ozone and heat [+ SALT] changing their resilence.
4-6 years depending on location. Depends on how near brand new you like to maintain.
Chrisfrend
It is worth replacing the rubber bushings -- you should be able to feel the difference. I've replaced mine in a 97 Q and it was a significant improvement resulting in a smoother ride.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
They're cheap and easy to replace, good investment.
Qproject
what about the stabilizer links? the one that attaches to the strut assembly.
bullittandy
The links are the cheap and easy part.
You may also have to replace the tension rods, strut mounts and struts.
If you're even halfway mechanical you can replace the sway bar links and tension rods your self. Strut mounts and struts require a little extra skill.
If you've got the money, replace all of it.
