S14 Stock (data from CourtesyParts)Front 27.2mm Rear 15.9mm
Whiteline Adjustables (data from PDMRacing.com)Front 27mm Rear 20mm (22mm available as well)
Suspension Techniques (data from STRacing.com)Front 28.6mm Rear 20.6mm
Cusco (data from Japanparts.com)Front 30mm Rear 21mm
Nismo (data from Japanparts.com) Front 30mm Rear 23mm
Tanabe (data from Tanabe-usa.com)Front 30.4mm Rear 27.5mm
Further Information:Nismo Stabilizer Kit (I thought the spring rate was interesting)Front: Diameter=30.0, Spring Rate=101.2mm(10.3kgf/mm) Rear: Diameter =23.0, Spring Rate=43.1mm(4.4kgf/mm)
Suspension Techniques data (from CourtesyParts.com)The stabilizer bar kits are manufactured by Suspension Techniques and include all mounting hardware and urethane bushings. Torsional rigidity is increased by 22% over the 27.2mm OE front bar and 182% over the 15.9mm OE rear bar (SE model).
S13 Stock ? (data from Japanparts.com) JDM ?Front 24mm Rear 16mm
Suspension Techniques (data from STRacing.com)Front 27mm Rear 20.6mm
Whiteline (data from PDMRacing.com)Front 27mm Rear 20-22mm
Cusco (data from Japanparts.com) Front 28mm Rear 18mm
Tanabe (data from Tanabe-usa.com)Front 30.4mm Rear 22mm
Further Information:For the S13: 24 and 25mm OE front and 15, 17, and 21 mm OE rear bars can be had from CourtesyParts.com
I've seen some data on some other bars but have not confirmed them yet or in some cases determined whether they are S13 or S14.Hicas rear bar for S13: 21 mm ?Largus 31.5mm 27.5mmD'Stage 31mm 23mm
Possible Sources: (have not verified them all yet)Suspension Techniques can be found at Enjukuracing.com, and possibly Nopi.com or Summitracing.comTanabe can be found at ProjectNissan.com, Enjukuracing.com, MVPMotorsports.com Cusco can be found at ProjectNissan.com, CIPmotorsports.com Japanparts.com and Nismo S14 bars can be found at Japanparts.com (brace yourself... pun intended...)
Antiroll Bar Changes (copied here from the Suspension FAQ)Modification - Effect on Suspension
Increase front rate - Front roll resistance increases, increasing understeer or decreasing oversteer. May also reduce camber change, allowing better tire contact patch compliance with the road surface, reducing understeer.
Increase rear rate - Rear roll resistance increases, increasing oversteer or decreasing understeer. On independent rear suspensions, may also reduce camber change, allowing better contact patch compliance with road surface, reducing oversteer.
Decrease front rate - Front roll resistance decreases, decreasing understeer or increasing oversteer. More body roll could reduce tire contact patch area, causing understeer.
Decrease rear rate - Rear roll resistance decreases, decreasing oversteer or increasing understeer. On independent rear suspensions, more body roll could reduce tire contact patch area, causing oversteer.
http://store.240sxmotoring.com/swaybars.html
