i plan on getting new swaybars myself. I have heard good things, but i am willing to bet that the night and day difference has to do with the replacement of the stabilizer bar endlinks, which tend to wear out.
i don't know if the ST swaybars are authentic on ebay, but the ones on enjuku's site are silver and the ones on ebay are green and i don't see any endlinks in the picture where as enuku's comes with them.
good link:
http://en.wikibooks.org/wiki/N..._Bars
wikipedia wrote:S13 OEM Sway Bar Options
S13: (Abs/lsd package) Front bar 25mm, 21mm in the rear.S13: (se without Abs/lsd package) Front bar 25mm, 17mm in the rear.S13: (non se) Front bar 24mm, 15mm in the rear.*All are tubular steel
Aftermarket Sway Bars
Largus - Front bar 31.5mm, 27.5mm in the rear. 3 way adjustable front only. Tubular steel construction. Stock type endlinks. Largus includes new bushings with purchase
Whiteline - Front bar 27mm, 22mm in the rear. Solid steel construction and 3 way adjustable. Whiteline users their own specific blade type endlinks
Tanabe - Front bar 30.4mm, 22mm in the rear. Tubular chromoly construction. Stock type endlinks
Progress - Front bar 27mm, 22mm in the rear. 3 way Adjustable front & back. Tubular steel construction. Progress supplies a heims type endlink on all swaybars.
Cusco - Front bar 28mm, 18mm in the rear.
Suspension techniques - Front bar 27mm, 20.64mm in the rear. Solid steel construction. Stock type endlinks
S14 OEM Sway bar
S14 Base model: Front bar is 27.2mm, there was no rear swaybar equipped. S14 (SE and LE package): Front bar is 27.2mm, 15.9mm in the rear bar.
Largus - Front bar is 32mm and 2 way adjustable, rear bar is 28mm non-adjustable. Tubular steel construction. Stock type endlinks. Largus includes new bushings with purchase. These swaybars will NOT clear the Greddy SR20 oil pan.
Tanabe - Front bar 30.4mm, 27.5mm in the rear. Tubular chromoly construction. Stock type endlinks
Progress - Front bar 30mm, 24mm in the rear. 3 way Adjustable front & back. Tubular steel construction. Progress supplies a heims type endlink on all swaybars.
Cusco - Front bar 30mm, 27.5mm in the rear.
Suspension techniques - Front bar 28.6mm, 20.64mm in the rear. Solid steel construction. Stock type endlinks
it looks like if your going to go ST, your probably just as good off to keep your stock front swaybar and replace the endlinks and bushings and just get the ST rear swaybar.
Largus is overkill and they cost 2 much.
