ST sway bars + rb
BoostFab
Car: S13cp, S13fb, S14z
some of you guys on here are using them with your rb+xmember swap, how is the sway bar?
i need to get one for mine, which one did you all get?
s13rb25
Car: 89 240
ive got st sway bars front and rear waiting to go on my s13, r33 rb25 crossmember, hope to have them on in a week or too when my other suspension stuff gets here. ill let you know how it goes when i do it.
BoostFab
is the front one adjustable or it's made w/ clearance?
goofynick6
Car: 1995 S14.5 RB20DET
I used stock swaybar, and turns out my RB20 oil pan is 1/8" from it, so I'm just going to put a few washers at the mounting point on the frame and make it a little lower and that should cure the problem.
Nick
frosted flakes
i had to make a custom 3/4" steel spacer in order to clear the oil pan with the stock motor mounts in the r32 crossmember.
BoostFab
frosted flakes wrote:i had to make a custom 3/4" steel spacer in order to clear the oil pan with the stock motor mounts in the r32 crossmember.
that sound like a good idea w/o buying a new sway bar. did you made spacer for the front mounting point? or at the LCA?
blk90s13
can someone show us some pics asap please
thanks guys
BoostFab
anyone know what material the sway bar is made off....maybe i can extend it w/ a mig welder...?
bobdhead39
Car: Cars maybe?
Check out my thread I started, it should help a little.
http://www.nissaninfiniticlub....65787
