ST sway bar on base s14
sixxdeuce
Car: 93 rx7, G35coupe 6mt
Has anyone installed a suspension techniques rear sway bar on their base model S14? If so did it come with everything you needed or did you have to buy some brackets also since the car didnt have a rear sway bar stock?
sixxdeuce
ok, I did some more searching and it looks like the ST bars come with the d mounts but the whitelines do not. But could someone please confirm this? Also it sounded like adding just the rear bar could have some negative effects, is this true? I just want one for the rear because theres nothing there now.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
well, to answer ure question on the whitelines, no they do not, however they do sell the plates extra for $11 in fr/$3.50 in rr ea. ....not sure if Cusco sells the brackets with the bars or not... sure wish i had an SE...
-Dan
