C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Thu Jul 31, 2003 5:44 pm
They are fairly easy. When you go to install the front brackets though, bend them out a little first. The bolt holes are bit too close together and can make it a bit difficult to get the bolt on without cross-threading it. Or you can use the stock brackets.
On the rear, you may need to unhook the exhaust from the hangers. That should give you enough room to pull the stock sway bar out(if equipped) and put the ST one in.
