pnutbuddy »
https://forums.nicoclub.com/pnutbuddy-u138547.html
Sun Aug 02, 2009 2:44 am
I dont have a way to post a copy of the report, but here it is: HC(ppm) standard is 174 @ 2300 rpm, current reading is 201 - failHC(ppm) standard is 180 @ 1500 rpm, current reading is 221 - failCO(%) standard is 1.12 @ 2300 rpm, current reading is 4.47 - failCO(%) standard is 1.01 @ 1500 rpm, current reading is 4.11 - failCO2 = 0.2 @ 2300 rpm, 0.5 @ 1500 rpmNox(ppm) standard is 1258 @ 2300 rpm, current reading 661 -passNox(ppm) standard is 1378 @ 1500 rpm, current reading 563 - passDILUTION: standard is >6.0 @2300 rpm, current reading 16.67 - passDILUTION: standard is >6.0 @ 1500 rpm, current reading 16.31 - passThis is what the VIR states, also all other safety items passed. Any help is appreciated, thanks. I have been told to just add a gas additive that guarantees to make your car pass the emissions test, to replacing different sensors, ie the O2, exhaust gas temp., egr problems, replace the cat...you see my dilemma, too much advice from parts houses! Again, thanks for any help.
