SSAutochrome fitted pics and Jon's GT25R (56k go check your timing)
USDM_OneVia
Car: Racing
Very large pics, but here you go.... Fit is very good. We fabbed it up with his GT25R on it first and we are going to have to hack half the mount out if he wants to keep it. Then we bolted it up with my S14 T28, SR Megan Racing o2 Housing, and HKS SR downpipe. It all fitted up great! I might pic one up, but I am still worried about cracking on it. But it is a pretty beefy piece.
Front view
Top Side of it....
o2 Housing
Mostly fitted up, good fit
GT25R on the right... that thing is MASSIVE
Just an idea on how big it really is....
btw.... motor is completely out of the car and on the stand. Fitting up the injectors, turbo, and lines tomorrow. Also got the flywheel off and going to have it resurfaced. Might as well have it done while it is apart. I am also going to lay down a fresh coat of paint and clean up the motor quite a bit and resolder some crappy wiring from before tomorrow. If my damn gaskets from JSpec show up I can have it all back together and back in and running Wednesday or Thursday.
Joe
float_6969
It does look really nice. I hope that it works alright as us CA ppl need a good cheap mani.
Rookie_ca18
Car: women, sleep, cars
OMG... now ive seen it all a hairdryer on steroids, hopefully that manifold holds strong and wont crack (fingers crossed).
Nismo1182
Car: Z06
GT25R is a nice bolt on turbo but the turbine will run out of flow at 21 psi and the big trim spools up around 4000 on a SR.
slw240sx
Car: 1990 Ca18det 240sx Hatch
im running the bigtrim and will be tuning for 17-20psi, if it runs out ill get the GT30 maybe ill down size to a t28 again if its too laggy, im torn between top end and low/mid end..
