I have that "rotator flange" kit you posted, its meant to let you use the S14 turbo with S13 hotpipe and S14 turbo inlet/outlet. It appears it will only work for you if you use the chrome outlet with s13 hotpipe.Chinamandrift wrote:
update ....
i found the adaptor ....FRSPORT carries them ........its specified for t28 turbo due to the clocked position......i believe the t28 and t25 are the same for the 3 bolt outlet........has anyone tried this ???.....it looks like this BUT after taking a hard look at it .....i need it to clock away from the pipes ....this adaptor clocks the outlet back towards the pipes
Modified by Chinamandrift at 6:51 PM 6/1/2008
Modified by Chinamandrift at 7:00 PM 6/1/2008
Modified by Chinamandrift at 7:09 PM 6/1/2008
Modified by Chinamandrift at 7:10 PM 6/1/2008
the bolt on the compressor backing. unless yours is different.look here:Chinamandrift wrote:is it the bolts ??? ......i thought it was the big C-clip ??? to clock the turbo ..sorry im new with the turbo thing
another thing is that i check my turbo on clocking it .......the previous owner had clocked it to its max already ....he had it on his SR20.........if i try to clock it anymore my wastegate wont be aligned with my hinge for the door.........as of right now the stem is comming in at an angle on the waste gate....i will take picures wen im off work to show you guys
