SSAC manifold options
Reignman
Car: 1995 240SX
Trying to find a mid-ranged priced turbo manifold without luck I wanted to see if this idea would work out. From what I read the SSAC manifolds crack because they are made of dissimilar metals (SS piping and mild steel flanges). Would it be possible to have the flanges cut off and have SS flanges welded on in place and also add some bracing? This way the manifold would expand at the same rate. I would also be running an exhaust flex pipe. Im looking for a manifold that could support a larger turbo (GT35) and still stand up on a daily driver car.
Nameless EJ6
Car: What the **** do you think.
There's no reason to go through all the trouble. It's just irrational thinking that you can yuppie fix a manifold originally designed by monkeys. It's like living in a single wide trailer and expanding on it to make it look like a regular house.. it'll always be a trailer. It's always going to be a horrible manifold. It's not quality in any way. Sorry.. but that's the truth. Don't like to see people compromising when it comes to this stuff. Buy a nice manifold and be happy.
cvc9216
mild steel flanges are not the reason ssauto manifolds crack. It is common practice to use mild steel for manifold flanges.
Reignman
Car: 1995 240SX
Does anyone have any experiance with this manifold?http://cgi.ebay.com/RB20-RB25-...wItem
It looks to be better quality then the SSAC manifold. The only problem would be the shipping from Australia
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
There are companys that can make you a manifold. Protech, Love FAB, Full race, peak boost. Protech is making my manifold for my RB20. It's not going to be cheap since I'm going with a true equal length with a merged collector. If you email them and tell them what your looking for maybe one of them can work with you to get you what you want.
eh?
Same manifold as SSA. IF you're gonna buy a cheap manifold buy this onehttp://cgi.ebay.com/ebaymotors...QrdZ1 for $89 I wouldn't spend more than $100 for that manifold.
Reignman
Car: 1995 240SX
I may just end up using the stock manifold with an external wastegate until I can afford a better quality manifold.
BoostFab
Car: S13cp, S13fb, S14z
i could build you an adapter to topmount turbo and external wastegatehttp://forums.nicoclub.com/zer...2.jpg
Reignman
Car: 1995 240SX
Can you post a pic of the adapter? I was just going to have a wastegate flange welded on the top of the manifold and use a spacer for the turbo.
BoostFab
i'm in process of buiding another one for someone; i'll try to get get a picture out when i have it finished.....if you need one right away, let me know.
