SS autochrome manifold issues
sil820
im really pleased with the amount of space the manifold saves..but thers not room for external wastegate...but looks like theres just enough room for a adapter to relocate the wastegate. Anyone know where i can get that made? And how much i would be looking at? the car isnt running so i would have to just take pics for someone 2 make it. i want the wastegate to sit under the brake boot and above the steering shaft. looks like there a nice big pocket there. ill take pics soon.
JonPowell
Car: Cars, Music, My family
I am working on making one now for the car I am building...in all reality its gonna cost me like $50 for materials...I dont know how much you want to pay, but get 2 T3 flanges, some 2x3 rectangular steel tubing, some 1.75 round tubing, and your wastegate flange...then ggo to town. YOu will need to cut & reweldf the 2x3 pipe so its 2x2.5 and then just assemble it all.
You will have the positioning perfect that way. I paid $20 for 2' of 2x3 and the 1.75 tubing.
sil820
so your using the same manifold? Only one problem is that i dont know how 2 weld....haha any chance you can me 2 of those and ill pay u
Imissmyturbo
Car: Car's, Turbo's, sking
you could have a wastegate flange welded onto the manifold since it isn't cast like the stock one. I have a topmount manifold with an external wastegate already built in. I am not sure weather or not I am going to use it since I will have to redo all my piping.
JonPowell
Nope, I am using the stock exhaust manifold with an ITS GTS61HP that is externally wastegaed and the adapter from ITS is T4. I have no idea how long you need it or where you need the wastegate so its kinda pointless to make one based on the measurements I take....they may not work with you.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
You might not want to hear this brian. If you mod that manifold it will crack faster. You put a external wastegate tube on that thing and it will crack at the external gate tube 1st then spread from there. Why didn't you get my buddies HK$ manifold?
Imissmyturbo
HKS's manifolds don't clear on LHD cars do they? I though it would put the turbo right at the steering shaft.
FrostyRB
Car: cars, bikes, atv's
Aren't the HKS manifolds flanged for a T4?
Yellow4g63
Imissmyturbo wrote:HKS's manifolds don't clear on LHD cars do they? I though it would put the turbo right at the steering shaft.
CarlH runs this manifold with a GT30R turbo. I'm sure you need a diffrent down pipe vs what you have for that manifold you have now.
Yellow4g63
FrostyRB wrote:Aren't the HKS manifolds flanged for a T4?
You can drill it for T3 or T4. If it has a T4 drilled then you can drill it for T3.
sil820
with the hks manifold it wouldnt clear. the turbo is about less then half an inch from the steering shaft.. well i dont want to weld on an external wastegate flange on the manifold i just want to have and adapter at the end.. that goes off the side
