Notchbackca wrote:the real problem is its made from stainless, you want a mild steel manifold. if the metal is softer it can withstand the strain from tempurature changes better
from a metalurgy point of view... the harder a metal is the more brittle it is
Myetball wrote:Matiral=MaterialMild=Milled (Mild is like un-spicey hot sauce)
My Brazilian turbo motor has a bracket that connects the turbo to the block. If SSA headers crack from hanging all that weight maybe fabricating a bracket to hold the turbo up would extend the life of the manifold.
Yellow4g63 wrote:Nope it's not that it's made out of Stainless steel why it cracks. if it were made out of mild steel it would still crack. Stainless has better heat properties than Mild steel.
Nathan wrote:Care to substantiate this? EVERYTHING I know about exhaust manifolds, systems, and steel in general says that mild steel expands less from heat and takes cycling better. Believe it or not, heat cycles can actually make stainless more prone to corrosion. Of course mild steel transfers more heat than stainless, but it also deals with it a bit better. It is my opinion that a well designed manifold made of the right kind of either mild OR stainless steel can be made that wont crack. The problem is that then you end up paying 1200 bucks for a stainless one if thats what you wantYou absolutely have to use thicker gauge tubing if you dont want cracking problems, especially with stainless.
Nathan wrote:Yeah, but the issue isn't so much a maximum heat issue...you'll melt the aluminum of the head and the pistons long before you'll significantly weaken the mild OR stainless steel. I'm more concerned by how the metals take heat cycling and how they deal with thermal expansion. My understanding is that stainless expands the most and also, the cycling is one of the contributors to cracked manifolds. All I'm really saying is that the SS autochrome mani's are awful thin and something made out of 8 ga. or schedule 40 thickness metal (stainless OR mild) will most likely last a very long time in comparison and might very well be worth it. Not trying to start an argument here![]()
